DAQ Channel Name Control Problems in RTengine
I am running Labview 6.0.2 and NIDaq 6.9.1f28 on a windows 98 PC. The new Daq Channel Name control available from the Front panel tool box seems to work fine in development version of labview. I can create channels in MAX and instantly select them using the Channel name control without any code. When I build a very basic application however, the EXE version does not work attall. It simply shows no channels?
Has anyone else seen this problem or have any ideas please?
Regards
Ian Billingsley
Billican
(2,869 Views)
I have the same software setup on one of my pc's and the exe version works fine. Are you trying it on the same computer that you run the vi on? If not, I would definitely try that out. Reinstalling some of your software might resolve the problem if it is on the same machine.
(2,869 Views)
I am having the same problem!
I am developing using LV 6.1 on a Win NT PC, but want to create an executable for a different NT PC that has the DAQ card in it.
I have NIDaq installed on both PC's and can create a vi on development PC with the desired channels, but the built .exe on the target PC has no channels!
If anyone can help it would be fantastic!
(2,869 Views)
