DAQ Assistant VI not working
Hello. Why do I have this error in labview? I have read that it is due to a lack of license, is it true? how can I solve that? Thank you
(2,324 Views)
Click the Start button in the lower left corner of the main Window.  Find the National Instruments folder and open it.  Run NI License Manager.
When you installed LabVIEW, it should have brought up License Manager and asked you to enter your License, or to log into you NI Account (if you have one).  It should show you what NI Products you have, and their Licensing state.  If some are unlicensed, you can click on them and enter your License Number.
(2,290 Views)
What version of LabVIEW are you using? It may be related to this bug that I believe exists in 2022 Q3, and 2023 Q1.
https://www.ni.com/en-us/support/documentation/bugs/23/-labview-2023-q1-known-issues.html
(2,273 Views)
I have the vesion 2020 for students
(2,267 Views)
Install NI-DAQmx 18.5 and it craches when i star using DAQ Assist
(2,265 Views)
If you use LabVIEW2020, you should install at least DAQmx 20 or a newer version.
(2,205 Views)
