DAQ Assistant Freezes - LabVIEW 2021
I created a simple DAQmx test .vi. It worked back in April. I was able to "see" and trend the temperature measured by an actual thermocouple immersed in water.
Now, I don't have the NI hardware connected anymore. When I open the .vi and right-click on the DAQ Assistant block and select properties, the DAQ Assistant window opens up and everything freezes. The "Channel Settings" panel is empty. Nothing responds, not even the "OK" and "Cancel" buttons. Windows' Task Manager does not show anything abnormal (LabVIEW 21.0 Development System (32-bit) and AF_NiAssistant (32-bit) running).
I am running Windows 10 with 32 GB RAM.
Any suggestions?
Thank you
(1,590 Views)
Here is a great opportunity to provide feedback to NI - https://forums.ni.com/t5/Multifunction-DAQ/DAQ-Assistant-Express-VI-Users-We-want-to-hear-from-you/t...
Santhosh
Soliton Technologies
(1,554 Views)
Done. Thank you!
(1,522 Views)
