DAQ Assist
I am currently having this exact same problem, but it looks like this post trailed off and never finished.  I am using Labview 8.5 and NI-DAQmx 9.3.  Input assist is available, however DAQ assist is not.  Does DAQ assist need to be installed to a certain directory?  Maybe I have it saved/named wrong?
Message 11 of 12
(347 Views)
If you installed DAQmx 9.3 after your LabVIEW installation, you should not have to specify anything other than the default install directory. LabVIEW will automatically associate the palette functions with the DAQmx driver. Are you missing any of the other DAQmx VIs in the Measurement I/O palette or is it just the DAQ Assistant?
Jake H | Product Manager
Message 12 of 12
(329 Views)
