DAQ Assist missing in LabVIEW 2019
There is no DAQ Assistant in LabVIEW 2019 Professional. I have tried 32 and 64 bit versions. If it has been removed, please bring it back.
Message 1 of 19
(6,453 Views)
If you do not see the DAQ Assistant in LabVIEW 2019 (32-bit), then you have not installed it.  When I open my newly-installed LabVIEW 2019 (32-bit) and open a VI, the Dreaded DAQ Assistant (the DDA, which I never use -- DAQmx is so much better) is right there.
Here are snippets of a blank 2019 VI with the DDA, as well as some of the Installed Software seen by MAX (showing DAQmx).
DAQ Assistant, LV 2019DAQ Assistant, LV 2019DAQmx in MAXDAQmx in MAX
Message 2 of 19
(6,437 Views)
I have installed DAQmx. MAX says the NI-DAQmx Device Driver is version 19.0.0f1. LabVIEW 2018 is working OK with this.
DAQ Assistant might be dreaded, but when a need a quick program to test hardware, DAQ Assist is handy to use.
Message 3 of 19
(6,429 Views)
Why write a program to test hardware? All of the functionality that you need to test hardware is available in NI-MAX.
Message 4 of 19
(6,423 Views)
Can you post a screen shot of the Software Tab in MAX?  Something seems to have gone astray somehow ...
Message 5 of 19
(6,409 Views)
Just to be sure you installed in the right order. Did you install NI-DAQmx 19 after LabVIEW2019?
Message 6 of 19
(6,401 Views)
I am talking about sensors, not NI hardware.
Message 7 of 19
(6,398 Views)
Yes, I did.
Message 8 of 19
(6,396 Views)
So am I. What can you do with a DAQ Assistant to test the sensors that you can't do with NI-MAX?
Message 9 of 19
(6,389 Views)
Why do you ask? I want DAQ Assistant and I don't get it with LabVIEW 2019. Even NI DAQmx is missing. I have also tried to reinstall Drivers DVD 19.1. Maybe I have to wait for the next DVD?
Message 10 of 19
(6,374 Views)
