DAC-issue
I am using PCI 5640R board. AD-9857 is the DAC.
I want to generate a signal(sine), digitise it in the Host, transfer those values to FPGA.
Through DAC I want to reconstruct that original sine signal and send it through Analog output port.
I will measure it in the AO port using some measuring device (oscilloscope).
 * I have used the Single tone mode of DAC effictively.
* I am having difficulty in understanding the QAM  mode of DAC.   How to use it
(2,972 Views)
You can download some examples for the 5640R at http://decibel.ni.com/content/docs/DOC-1710
Do you have some prior experience working with the 5640R?
The PCI-5640R offers different programming options.
1. Host-based processing - you can work with LabVIEW and use the NI-5640R instrument driver.
2.FPGA processing - you can use LabVIEW FPGA module along with LabVIEW and program the onboard FPGA.
The  NI-5640R instrument drivers can be found here
You could also refer the IF RIO manual for more information.
http://www.ni.com/pdf/manuals/374603b.pdf
Denver
AE, NI India
(2,929 Views)
Hi Denver,
I have just started with LabView. Thanks a lot for your kind help
(2,925 Views)
