Cyclic Autocorrelation
I would like to know if labview supports 'cyclic autocorrelation' function or how it can be implemented in labview ?
Thanks and Regards,
~Algol
(3,090 Views)
The following website defines and discusses cyclic autocorrelation functions, which are there defined as the fourier coefficients of the autocorrelation function:
LabVIEW has frequency domain functions which you may find useful - but the palette navigation will depend on what version you are using.  Either way, they won't be hard to find 🙂  How to implement the solution in LabVIEW is a design choice, the same as it would be in any development environment.  If there is something about LabVIEW specifically which isn't clear, definitely repost and I'll continue to try to help!
Best Regards,
JLS
Best,
JLS
Sixclear
(3,080 Views)
Hi Algol,
did you succeeded with the implemetation of the CAF in LabVIEW? I would really like to have some news about your task.
greetings,
C
(3,005 Views)
