Customizing the Run Time Engine Installation
     I would like to create (or modify the existing RTE installer) to only install the component "NI LabVIEW Run Time Engine 8.5.1" and leave out the other 4 remaining components (Variable Engine, Data Socket.....). I thought that maybe I could create an empty project and build an installer for the empty project but that did not produce as clean of a solution as I would have liked. I still had to create a fictitious name for an application that did not exist and once it was installed the fictitious name appeared in Add/Remove Programs.
    The reason for this is very large C written windows program calls a LabVIEW 8.5.1 written DLL. The DLL is installed as part of that application. I hope to keep the installation of the necessary Run Time Engine as simple, small and minimalistic as possible.
    Could it be possible to modify the NI provided RTE (http://joule.ni.com/nidu/cds/view/p/id/1019/lang/en)? Perhaps by modifying settings in the "setup.ini" and then removing unnecessary data in the "Products" folder?
Thank You,
Glen
(2,897 Views)
Hi Glen,
Try using the "LVRTE851min.exe" executable found on the LabVIEW Run-Time Engine 8.5.1 download page (linked in your post.) The page states that it is used for remote front panels, but in essence, it is an installation of the Run-Time engine without the supporting modules.
Message Edited by Captain Kirby on 07-17-2008 03:20 PM
Asa Kirby
CompactRIO Product Marketing Manager
________________
Sail Fast!
(2,863 Views)
Thank you, I saw that but was afraid to use it because I was unsure of its purpose. The size of that installer is comparable to the 7.0 installer that we are moving away from.
Thanks again,
Glen
(2,858 Views)
