Customizing an XY graph
I am currently working on writing a program to replace one that we currently use (it runs on MS DOS... so... yeah).   Attached is a printout of the graph that the old program creates.  There are currently 2 things that are present in the charts created by the old version of the program that I am not sure how to replicate in LabVIEW.
1st is the legend that appears in the top-left corner.  I have string constants and controls that allow the user to input all of that data, and it is currently saved with the data as text, but I don't know how to make a legend like the one shown appear on the LabVIEW graphs, and it would be nice to include it.
2nd has to do with the y-axis.  In the attached chart, there are 3 seperate plots that appear on the same chart, labled X, Y, and Z, and although it is all on the same graph, the y-axis is divided into 3 segments of +/- 5 dB.  I have worked out (with some help from these forums) how to make it so that the user can choose whether he wants all 3 on the same chart or not, and how to offset the values on the chart, I just don't know how to get the y-axis to reflect that there are 3 graphs on 3 seperate axis.
The last thing I need to keep in mind for #2 is that there won't always be 3 runs on the same chart, sometimes it will only be a single axis that I need to test, so only 1 plot will be generated.
(3,964 Views)
The y-axis thing I wasn't sure if LabVIEW would be able to do or not, but it would really suprise me if LabVIEW won't let me put a caption like the one attached in the last post on an XY graph.  I've been playing around with property nodes and I can't find anything that takes arrays as a data source.  I attached a pic of how I thought it would be able to work.  Worst case: It looks like I should be able to take the most important string inputs, put them all into a single string (not an array, just seperated by commas) and add a single line of text to the graph (though I am not sure if that caption will also be saved to a file if I use a get image property node).
Is there seriously no way to add a useful caption/label to my XY graph?
(3,919 Views)
You can create a custom XY Graph. Place the caption at the top left of the graph display and make the caption background white (or any color you want). You can create a small subVI that will format your array input into the caption string. The caption will be saved to a file. (haven't tested it but when you right-click and export simplified image the caption is part of the image).
Ben64
(3,906 Views)
Hey, thanks Ben, but could you repost that in LabVIEW 8.5?
(3,904 Views)
Sure, here it is.
Ben64
(3,901 Views)
Awesome, thanks so much.
(3,898 Views)
