[Customizing/Making indicators] GUI, wishes and dreams, but can it be made?
I'm not completely new to LabVIEW, I already have basic programming skill with it (more extended knowledge of C/C++/Pascal and so on) and untill now I was able to reach my targets depending functionality. However for a job I got offered I intend to use LabVIEW more as a interface to the user, so I have to create a nice and fancy looking GUI. Things that I need are more or less like the standard indicators only altered to suit our graphical demands.
Because I'm completely not familiar with modifying the looks of the controls and indicators to a higher level than standard offered by ie. the property nodes, I started to read the manual. Although reading that didn't give me all the information needed (or at least not clear) on how I and where I should start such an attempt. Just by trial and error I managed to get some better looks on some indicators but some things I couldn't get the way I need it.
I Hope I can make myself clear in what I need and what I want, if I'm if not really clear in the way I answer or the way I wrote this thread, please say so, because English is a foreign language to me.
List of goals:
1.) Upsidedown 'meter' indicator:
Special:
* Scale - Left side from let's say 90 to 0, right side inverse, but positive, so 0 to 90 (fixed range)
* Needle - Arrow as needle or something like that, prefered scalable
2.) Rotating scale 'meter' indicator:
Special:
* Scale - Left and right like the upsidedown type (90 to 0 to 90), also "common zero" (no negative values)
* Needle - Fixed in the middle of the display (possibly only a 'thick' vertical line) (fixed)
3.) Shifting scale 'bar' indicator (rotating dial in English?, only seen from the side):
Special:
* Don't know how to do this, number of problems will probably arise
* Scale - From 0 to 360, turning from left to right and the other way around, always displaying +/- 15 of the scale relative to the actual value
* Needle - Prefered a 'see-through' type or 2 vertical lines with some space between
4.) Needle: 'Gauges' with larger arrow:
* Scale - North/East/South/West in stead of 0-360 degrees, but using 360 steps from North to North passing South
The added pictures are from our previous solution, but externally made by a software engineer, we want something we can make and support.
For all graphics to be made it's a pre to be able to alter colors and that the indicators scale with the resolution of the display (with the least amount of artefacts possible)
Talking about realizing above things, is it possible to create indicators from scratch or should I better just change the standard indicators from the library? In both situations can you please provide me with some information on which menu's to use or a quick walkthrough, if possible.
Hope some of you can make this project a succes,
Kim
Message 1 of 35
(10,603 Views)
Dang!
Kudos to whomever designed those... they really look nice.
I dont think you will be able to customize (in LabVIEW) a standard control to do what you want.  You might be able to use a picture control and draw everything from scratch but I would look into making them ActiveX and importing them via an ActiveX container:
I dont offhand know if this is the best solution or not.  Its your cat, skin it anyway you like Smiley Very Happy
Message 2 of 35
(10,571 Views)
First attemp....
I imported the image in a gauge and only kept the arrow after matching sizes. I have replaced the needle with the arrow in the decoration palette.
LabVIEW, C'est LabVIEW
Message 3 of 35
(10,569 Views)
Some ideas for the second gauge.
Note that you will have little flexibility if you want to resize these custom controls or change colors.
Message 4 of 35
(10,544 Views)
Wow, thanks for the fast replies to my question, always nice to see enthousiastic programmers. Tomorrow I have a day off and I can't check the forum untill 7PM CET, thus I will check this forum as soon as I can.
I Already got some things done by using your replies, which gave me a push in the right direction, check the attachement. (Just demo). Thanks alot, greatest problem I think is to get a 'bar' rotating from left to right to display heading info, (transition between 0 and 360)...
Message 5 of 35
(10,531 Views)
Try reading in your png files and turn them into a picture. Feed this picture into the picture input on the polar plot demo file.
Message 6 of 35
(10,497 Views)
Here is a quick example (7.0) of making a rotating dial using an XY graph. The main problem is that this isn't very smooth. A picture control solution might be better.
It basically uses 8 cursors to have the text and it moves the cursors. Once the leftmost cursor is off the graph, it is moved back to its original position and takes the text from the second cursor.
___________________
Try to take over the world!
Message 7 of 35
(10,478 Views)
I think the scale demo picture control would work for the rotating dial.
Message 8 of 35
(10,470 Views)
Here is a rough rotating scale with a picture control. 7.0 format
Message 9 of 35
(10,452 Views)
Great! Got almost everything more or less the way I want it, only producing the heading 'bar' is very difficult for me Smiley Sad.
The approach like 'test' by using a XY Graph gives the best result untill now, one thing that I noticed is it certainly costs some processing time and you can see that the cursors shitft to the left one by one (however this isn't a great problem, because the display doesn't need to move really fast). What I'm also missing (and I don't even get close fixing it using the XY graph) is some vertical lines that indicate every '1' by a small one and every '5' by a larger line, is it easy to produce, or does it result in a very high CPU-usage? I May sound a bit stupid but when I want to connect a control, I'm not sure where to place it.
'unclebump'-s  Idea should work better at least that's what I derive from the reactions, only it's always jumping 5 positions at a time, it should be a smooth horizontal moving bar, but with markers at every 5 points. Also same as above, never worked with a picture control, for me it's difficult to understand the chosen numbers and actions with comments.
Speaking of the "rate of turn" indicator, it needs to be working both ways from .... to 0 to .... (check demo/example below), and only 1/5 or so be visible...
And just to prevent too much work, it's not a prerequested fact that the graphics must be pictures, I'm very pleased with the results already (also perfectly scalable) by only altering the standard controls to a color standard and needle stuff and so on.
Possibly a demo will provide more info on what I want Smiley Wink? Check it out: http://www.kimjansen.nl/conning/nav442-3.swf
Message 10 of 35
(10,426 Views)
