Customize LabVIEW software
I want to customize LabVIEW software. In that software I want Tektronix multimeter DMM 4050 6-1/2 Digit Precision data display in UI. and one hardware tool, use of that CAN  data also  be display in UI. For that Software which of driver is required to install.
(1,432 Views)
Hi there 🙂
For the DMM you need: Tektronix DMM4050
For the CAN protocol, you need NI-XNET
Make sure to download the correct version of NI-XNET, compatible with your LabVIEW version. [NI-XNET Driver and LabVIEW Compatibility]
Cheers,
(1,367 Views)
