Customize Error Code
If there is an error in my subvi, in the error cluster, I would change the status to True and the source to my error message.  I usually don't change the error code at all.  What are the advantages of using error code?  If I have multiple drivers and they all have etheir own error code, won't there be a conflict?
(3,553 Views)
The code provides detailed information on the error. If you use the recomended ranges for custom error codes and don't create multiple custom error files, you will not have conflicts.
Your statement about multiple drivers is confusing. What sort of driver are you talking about and what sort of errors?
(3,550 Views)
How does the code givesextra enough if I put all the error information in the source entry of the error cluster?
Let say I have 3 seperate drivers, and each driver uses errro 5001, 5002, and 5003.  Won't that be a conflict?
(3,540 Views)
Usually the error message displays all the possible causes. In your case, if you get error 5001 it will list the 3 messages.
As an example: here two possible causes are listed for an error 5000
Ben64
(3,535 Views)
If you have multiple custom error codes, perhaps you should have a central clearing house for assigning those codes.
If you do create custom error codes, you do not need to manually populate the source string and can use it like it normally is to show where the error occured - you now the source of the error. I don't think I would like your unusual way of error handling.
(3,528 Views)
