Custom scale in intensity graph
I'm plotting a 2D array into an intensity graph with axes depth (y-axis), and phase difference in rads (ranging from 0 to pi) (x-axis). I have used the scale multiplier and got the y axis fine, but I'm wondering if it possible to have the x axis range from 0 to pi, with major ticks being factors of pi, and also have pi displayed as π rather than numerically.
Cheers
______________________________________________________________
(3,471 Views)
Hi Gazebo,
hide the x axis and place a 2D image indicator instead. Then draw anything you like to display in this area!
(3,459 Views)
It isn't hard to create Phase Marker Values of 0, pi/4, pi/2, 3pi/4, and pi, and to display these with two digits of precision, but it is a little odd having fractions there.  How about displaying degrees instead of radians?  Then you could label the axis "Phase (°)" and put down the numbers 0, 45, 90, 135, and 180.
I read Gerd's reply, but I'm not certain, myself, how I'd make the appropriate Image.  While I could probably figure it out, the two things that I've actually tried, above, are really easy to do, take little "code room" on the Block Diagram, and won't confuse someone reading my code three months from now.  It's too bad we can't use an array of strings as markers (instead of numerics), which would let us Have Our Cake and Eat It, Too.
(3,428 Views)
