Custom scale G Force measurement from accelerometer
I need help with my task, so i using kistler  50g its sensitivity is 100mv/g Single axis accelerometer, measurement using NI 9234 module, so question is how can i get G values, there is already a conversion configuration in DAQmx, usually at ground
it should show 1G, but it shows vibration values and not G values. The experiment is to drop a setup from a high of 50m and measure the G force.
If I should proceed to custom scaling, what values should i give it to the table, i never used custom scale before.
(748 Views)
Why don't you calibrate your accelerometer?  To do this, you need a stable level platform (put a ball bearing on it and make sure it doesn't roll).
  • Put the Accelerometer on the platform with the Axis pointing "up".  Record (with an oscilloscope) the output voltage.  [You want an oscilloscope to be sure you don't have excessive high-frequency "noise" in your signal).  This reading represents 1g acceleration (or -1g, the convention is a bit flexible].
  • Now repeat, with the Axis pointing "down".
  • Assuming your accelerometer is linear in the -1g to +1g range, solve the equation "Volts = bias + gain * Accel" for "bias" and "gain" (with  your two pair of Volts and Accel readings).
One thing to note -- a 1-axis accelerometer only measures one dimension.  In principle, if you put your accelerometer on a table with the axis pointing horizontally, moving it on the table top should give you no appreciable reading (especially if you move it "smoothly".
(733 Views)
DAQmx scaling for an accelerometer can be configured with the following units:
You do not need a custom scale.
Which model of Kistler accelerometer? If you need to measure gravity, a MEMS accelerometer is recommended. However, the 9234 is designed for dynamic (vibration) sensors. For an IEPE sensor, each 9234 channel provides power (>= 2.0 mA IEPE excitation current) and removes sensor DC bias voltage (using AC coupling filter) so the ADC is not overloaded. The AC coupling filter is specified:
NI does not recommend SV modules for precision DC measurements.
Doug
Enthusiast for LabVIEW, DAQmx, and Sound and Vibration
(692 Views)
