Custom palette for newly created instrument driver
I've created all the VI's for my new instrument driver, now I want to create mnu files so when I distribute the driver, it shows up on the end user's palette. Where can I find a tutorial that steps me through this process for LabView v8.6.
I've created mnu files, but when I place the vi and mnu files in the instr.lib directory, I get palette icons for each of my instrument driver subdirectories plus the mnu contents. How do I make only the mnu contents appear on the palette?
(3,258 Views)
Create the following dir structure:
Mydriver.mnu           //the palettefile
_Mydriver                // folder containing the driver, make sure it starts with an underscore (_)
_Mydriver\Mycode   // the actual code
Now you can easily zip 'm up and distribute. make sure the menu refers to the code in the 'underscore' folder.
Ton
My LabVIEW Ideas
(3,253 Views)
Accepted by topic author David673
Are you using the recomended project style driver? If you used the wizard for this, then you would have the mnu files in the project. In the help, there is a topic Instrument Drivers>Modification Instructions and it talks a little about updating the mnu files.
If you distribute a project style driver, the mnu files should be correct and any example VIs would be automatically added to the LabVIEW example finder.
If you did not create a project style driver, it might be something to consider if you want certification.
(3,239 Views)
The project wizard got me going in the right direction. Using that as a starting point, I was able to complete my driver.
Thanks for everyone's help!
(3,209 Views)
