Custom numeric control values, uneven increments
Hi, I want to create a numeric control with some custom behavior, so that I can use it in several VIs without copying the logic. I have the basics working in the attached VI, but I don't see a way to use it in another VI. Basically, I have a regular numeric control, but I want its values to be constrained to a finite set of legal values in non-linear increments; and when a user types in a value it gets coerced to one fo the legal values.
Is this possible to implement as a sort of custom control?
(2,934 Views)
I would recommend that you take at look at turning this into an X-Control. X-Control are custom controls that actually have processing associated with them. Once written, the control looks like a simple terminal on the block diagram but in reality there can be a fair amount of processing that takes place under the hood.
Fair warning though, X-Controls can be tricky to get working. However, they are extremely powerful.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(2,927 Views)
Hi Mark, thanks for the quick reply. It does seem that an XControl is what I want to use. My only trouble now is that I'm working on a client's Full Development version of Labview, and XControl authorship requires the Professional Development version.
Is there another -- perhaps less elegant -- way to get my VI version of the control to be reusable in other VIs?
Thanks!
Arthur
(2,923 Views)
