Custom increment/decrement button
In a numeric control I'm trying to substitute the increment/decrement buttons with simple triangles facing up/down respectively.
I understand it's possible to do this under Advanced>Customize. The problem I have is that I can only change the appearance of the buttons in the state where they are not activated. As soon as I click on one of them the original shape appears for as long as the button is pressed.
Is it possible to change this activated button as well?
Dominik
(3,338 Views)
In the control editor, customize mode, right-click on the increment picture. You'll see the item Picture Item>. That allows to select which picture state you want to edit.
LabVIEW, C'est LabVIEW
(3,330 Views)
Ahhh, very nice!
Thanks a lot, Jean-Pierre
Dominik
(3,317 Views)
