Custom high and low times for square waves
Hi, is there a way to create a square wave that has an incremental HIGH pulse width and a fixed LOW pulse width?
Sorry I'm quite new with labview, any help is appreciated, thanks!
(7,951 Views)
Hi, here is my solution, it simply alters the frequency to offset the change in duty cycle.
Hope it works for your application.
Joel.
Joel G
National Instruments UK & Ireland
(7,915 Views)
Accepted by topic author GBPC
Hi GBPC,
My name is Jack and I work at National Instruments UK.
I understand you are trying to output a square wave signal with a fixed low time and variable high time in labVIEW.
The reply above works great if you want to use the signal internally. Alternatively if you are trying to output the signal with a piece of internal or external Data Acquisition (DAQ) hardware you will want to use LabVIEWs DAQmx Tool palette.
I have created a quick example below for you to look at that should help you come to a solution. It uses the DAQmx VIs to create and initialize a channel and then runs it in a loop with controls to change the high and low times using a property node.
Hope this helps
Jack. W
(7,906 Views)
Thank you both for the great solutions, they're very helpful!
(7,888 Views)
