Custom control
I am using Labview 7. I tried to make a valve by converting a front panel switch using custom control. It is working but I can't resize it when I use it on a VI front panel. Secondly the valve property nodes are not working. Say when I put it to blinking the property is not activated. Can anyone help ?
(1,139 Views)
Hi tanmoy,
When customizing controls you probably added/changed pictures on the control: you still can resize the control, but it may look ugly then…
Which property nodes do "not work" anymore? Do you get any errors when running your VI?
(The blinking property is somewhat special as it only works for certain elements of the control and only operates on certain colors…)
(1,122 Views)
