Custom XML Processing Information using LV XML API
I stumbled across a behaviour that might eiter be a bug or intended behaviour. I'd like to know which of both it is indeed...
In the attached VI, I create a DOM Doc and try to create custom processing information. But it seems, the standard processing information is created also, although I don't want it.
Please see attached VI
I haven't managed to get rid of the default information (using the API)
Cheers
Oli
(3,404 Views)
The NI XML New.vi automatically generates the standard information because LabView uses UTF-8 encoding by default. So it isn't a bug.
When using the invoke node "append child" then you get both lines. You should first try to use "remove child" or "replace child".
Thomas B.
(3,221 Views)
Hi Thomas,
thanks for the suggestion. I've already tried to do so, but failed....
Anyway, I have a workaroung in place... Loading a fixed string into the DOM Document
Cheers
Oli
(3,218 Views)
