Custom Polar Plot
attached converted to labview 2010
 I think it's quicker to re-write than to modify  "PG angle labels.vi", as it does contain protected vi, which itself is very likely to contain a .dll
Message 11 of 28
(4,734 Views)
@Sonti_11532 wrote:
You have drawn the polar plot on XY graph. But how to create the auto circles and cross lines as per polar plot?
circle_lv2010 could be extended to do this
it's a couple of circles and lines (actually, several 1d arrays of x,y points arranged in a certain way)
put together with "build cluster array"
the XY Graph offers us a convenient  way of labeling certain points within the displayed image using annotations
Message 12 of 28
(4,724 Views)
Wow its looks awesome.....Please share the VI.
Message 13 of 28
(4,712 Views)
Basically XY graph is showing the Positive and negative scales. But i have a radiation pattern data with angle and amplitude. Most of the amplitude values are negative values. How XY plot will take the angle (Phase) reference which is 0-360. Please find the enclosed CSV file for data and plot.
Message 14 of 28
(4,710 Views)
as already shown in circle_lv210.vi, you have to do a coordinate transform before feeding the data into the XY Graph
your data is in a polar form, which is convenient, as there is a polar to complex function:
http://zone.ni.com/reference/de-XX/help/371361P-0113/glang/polar_to_complex/
z = r*cos(theta) + i r*sin(theta)
r ... amplitude
theta ... angle in radians (so you have to transform your degrees to radians via (x/180°)*π
Is there a global maximum amplitude you'd expect?
Message 15 of 28
(4,703 Views)
But same data if I plot in polar plot the pattern is different. Please see.
Message 16 of 28
(4,708 Views)
when I plot spiral.csv to the built-in labview polar plot, I get this:
now what?
Message 17 of 28
(4,705 Views)
I don't know why it is showing in your case. Please find the enclosed snippet. i didn't do any data conversion.
Message 18 of 28
(4,701 Views)
okay, this has something to do with the Spiral.csv ‏9 KB file itself -
I assume this is some kind of text encoding error.
I'm located in Europe right now
Could you do the following:
spawn an numeric 2d array indicator in polar snippet.png ‏24 KB and run the .vi
now, this 2d Array should contain all magnitude;angle values
then "right-click..data operations...make current value default".
Save the .vi and re-upload, so I can have a look again.
Message 19 of 28
(4,687 Views)
Nevermind, I re-downloaded the .csv, used your snippet directly
and I get the same plot for the built-in polar plot.
Now, my intention was not to re-write the whole polar plot api, but rather one of the sub-vis, namely PG_labels.vi
But indeed, my demo would need some extra scaling*   to render the same picture on a XY Graph in comparison to the 2d picture plot:
*(and besides that some more features like proper error handling etc.)
Message 20 of 28
(4,680 Views)
