Custom Create tag error when VI is compiled
MY vi runs fine in development mode but generates a custom create tag error - 33164 when running the compiled version
(2,819 Views)
Can you tell us a little bit more about your VI? What software versions are you using?
(2,819 Views)
The VI was developed with LabView 6.0.2 and we are using Fieldpoint explorer version 3.0.1.
The VI worked fine but we were having problems with our FP-1600 because it could not maintain an Ethernet connection.
NI sent us a new FP-1601 and the ethernet design flaws of the FP-1600 were no longer causing us problems.
Power was cycled on the system a day or so after that and ever since then the compiled version of the same VI will generate the afore mentioned error code, but the VI works when run in debugger/development mode. Re compiled, re-installed FP explorer, re imported fieldpoint tags; None of these worked.
(2,819 Views)
