Custom Control Hourglass
I'm liking this solution. With a little more refinement to the hourglass image (copied into the background of the tank control, you could even get the streaming effect. You can also make the slider fills images, but these SCALE as the slider value changes, which might look weird... or could be perfect.
_____________
Creator of the BundleMagic plugin for LabVIEW!
Message 11 of 14
(1,493 Views)
I got interrupted before posting so others have suggested  this - a tank behind decorations.
Lynn
Message 12 of 14
(1,487 Views)
Here's ,my last shot. looking pretty good. it would be great if it were possible to set fill images on the tank control at run time, or move rather than scale the fill images. I don't know. But still, this isn't bad!
_____________
Message 13 of 14
(1,480 Views)
Hi littlesphaeroid,
This is the solution i am looking for. You are right on target. I am able to (version converted to LabVIEW 2010) open hourglass2.vi. But i wish to see the hourglass3.vi. It says that "hour glass demo.ctl' is missing. Could you please downconvert hourglass3.vi to LabVIEW 2010.
Thanks.
Message 14 of 14
(1,454 Views)
