Custom Configuration File-Display Scaling
A few months ago you helped me to ignore the user dezimal point setting by adding a line to the Custom Configuration File.
Now I do have a similar request:
My LabVIEW-app should run on an Winwows-instrument that is using 125% display scaling.
This scaling makes the GUI of my LabVIEW-app too big and I should scale it down.
Is there also a Custom Configuration File-setting, that allows to ignore the local setting and scale the LabVIEW-app at 100% ?
With thanks and regards
Petr
(1,907 Views)
Hi Peter,
No.
(1,894 Views)
Thanks GerdW.
Perhaps an suggestion for a future release ... .
(1,876 Views)
Not sure of your scaling issues, but you could write a custom ini file for your exe. In this ini file you specify the fonts and font sizes. That helps alot with some scaling issues.
(1,868 Views)
Thanks a lot mcduff, I'll give it a try
(1,861 Views)
Something like below in your exe INI file. (Depends on font and size you want. Pick a font that should be on the majority of systems)
FPFont="Segoe UI" 24
appFont="Segoe UI" 24
dialogFont="Segoe UI" 24
systemFont="Segoe UI" 24
BDFont="Segoe UI" 24
(1,847 Views)
