Custom Bool Control with Decorations
Alright so I've been using these for quite some time but only recently realized I don't actually know how they were made.  I can't seem to track them down to a specific file, as they're usually just copy pasted across.  It's a Boolean Control that seems to be made up completely of decorations, but these decorations act as a single object.  When the state changes, the entire decoration object changes it's color.  It's not an image either, as you can right click->properties to change the color of true and false and it changes what the decorations object uses.  I've been able to somewhat replicate it by replacing the light part of a boolean control with a decoration, but I can't seem to make multiple decorations be counted as a single copy to import onto the control.  Any ideas what they did?
True:
False
Message 1 of 11
(3,299 Views)
This decoration is one piece, not made up with multiple parts.
It's from LabVIEW Datalogging and Supervisory Control Module.
George Zou
Message 2 of 11
(3,287 Views)
Ok, then my question changes to how do you make a custom decoration?  Obviously this decoration is not in base LabVIEW (unless I'm absolutely blind) so it had to come from somewhere....
Message 3 of 11
(3,277 Views)
If you want to add multiple decorations to a control, you have to do it piece by piece.
George Zou
Message 4 of 11
(3,271 Views)
Accepted by topic author EthanHenry
The decorations in the attachment are built-in to LabVIEW, but not on the palette.
Message 5 of 11
(3,269 Views)
There's also this boolean which is built-in but not on the palette.
(Note that you can right-click on it and add segments.)
Message 6 of 11
(3,262 Views)
Wow well I stand corrected.... Good old LabVIEW... Thanks!
Message 7 of 11
(3,250 Views)
Message 8 of 11
(3,243 Views)
@zou wrote:
You can find 4000+ decors at:
https://lavag.org/topic/19186-all-labview-decoration-objects-image-ids-0-to-4096/
Unfortunately, that VI is no longer there.
Message 9 of 11
(3,161 Views)
It's there, but you need to be logged in to download.
___________________
Try to take over the world!
Message 10 of 11
(3,150 Views)
