Curve Fit for PhotoVoltaic
This is an implicit fitting problem.  If you are using LabVIEW 8.0 then there is an example of this type of fitting (examples\math\curvefit.llb\Fit Circle.vi).  The basic approach is to treat I and V as separate domains as in a multi-dimensional curve fit, and create a range of zero.  For your model subtract "I" from both sides to get one side equal to zero. This is a function of I, V (and the other parameters) F(I,V, ...)  Now, for every IV point F(I,V,...) should be zero.  Follow the pattern used in the example to finish the problem.
Do you have any IV data you can post, along with the other parameters (k, T, q, ...)?
Message 11 of 18
(1,607 Views)
You need to return to the fundamentals of curve fitting.  Curve fitting is the art of minimizing the error between a set of experimental data and a theoretical model.  The key point is "minimizing the error".  What you wish to do is take your equation and minimize the distance between the points you generate and the points you have experimentally determined.  It is up to you whether this error is error in the V dimension, error in the I dimension, or error in both.  In any case, you can create an error function.  I would strongly recommend you use a linear (error proportional to linear distance) or logarithmic error (error proportional to log of distance) model rather than a squared model (error proportional to square of distance - used by least squares routines).  Technically, these correspond to a double exponetial or lorentz error distribution instead of a gaussian error distribution.  They are much more tolerant of experimental errors.
Now that you have an error function, you need a way to minimize it.  LabVIEW has several minimizers.  I would recommend the downhill simplex, since it almost always works.  You should rerun it when you finish, however, to make sure you didn't get hung up in a local minimum.
Please read the section in Numerical Recipes on robust curve fitting to fill in the details.  I can't explain it anywhere near as well as the book does.
Message 12 of 18
(1,599 Views)
I had already attach the data and the program i wrote.
I have gone through the example of the circle fit.
There is four input for the equation x offset y offset radius and  noise sigma to generate the graph and  fit values .
Sorry i still dont fully understand the example and relate it to my situation
Please bear with me.
As shown in the program i wrote is simple.I only have a simple understanding on Labview .
I have already ordered the book adviced and it will arrive soon. But i would like to solve this problem i am having to move on with other my work.
Please explain more
Message 13 of 18
(1,579 Views)
I looked at your data, and tried substituting into your model, but couldn't make sense of the results.  Take I=0A, V=18.8V.  Looking at your equation the exponent of e is q(V+IRs)/kT.  I=0, so the exponent is qV/kT=1.6E-19*18.8/(1.38E-23*298)= 715.9.  This is a very large exponent.  exp(715.9) returns +Inf.  Do I have your model wrong?
Message 14 of 18
(1,568 Views)
Sorry, copied the exponent wrong.  The exponent of e is 731.4.  exp(731.4) results in +Inf.  Same result.
Message 15 of 18
(1,566 Views)
So sorry you have to divide the voltage datas with 36 as the data is for 36 solar cells.
I have attached a new data giving the actual voltage .
Just receive my book today.
Reading the chapter mention
Message 16 of 18
(1,550 Views)
Hi DevChander i have already found a way to solve my problem manually.
Now trying to build a program on labview so solve it for me.
Anway just to inform you that i am still waiting for you sample programs.
Want to first thank you
Message 17 of 18
(1,527 Views)
Sorry for the delay chtan23.
But I could not get LabVIEW installed on my system as yet.Smiley Sad
will see what best i can do to get those fromulas. will keep you posted
Message 18 of 18
(1,523 Views)
