Cursor dragging
I have an x-y graph with a cursor. I have two ways to move the cursor: one is by dragging and the other one is by clicking a scroll bar that will send the value to the Cursor.PosX property node. Scroll bar is for fine adjustments. My problem is, if I drag and move the cursor, it will not set the value to the scroll bar, so it will move back to wherever the scroll bar value is at. If I can find a way to let LabVIEW detect the dragging action, then I think I can set the new position to the Cursor.PosX property. I couldn't find any properties there to do this kind of job. Any one can give some advice about how to work around this issue? Thanks in advance,
Guangde
(2,968 Views)
Hi Guangde,
I have posted a example on our community site that should demonstrate what you are trying to do.  Basically we need to update both scrollbar and graph based on a change to either.  I will give you a call in a little bit to make sure this is what you were looking for.
Sincerely,
Jason Daming
http://www.ni.com/support
(2,927 Views)
