Cursor dragging in LV2015
Hi all,
I have a problem with selection and dragging of a cursor in a waveform graph.
I have made two free cursors, but I can drag only one of them (the one created first) with the mouse.
Wherever I click on the waveform graph, the first cursor is activated (indicated in the cursor legend).
I haven't encountered this so far in any previous LV version.
In the previous LV versions, the cursor becomes active if you click on it, then you can drag that respective cursor.
Is this a known issue in LV2015?
EDIT: Thi sonly happens when the graph is in log scale!
(3,223 Views)
I'm unable to reproduce this behavior in LV2015. Can you post your VI (or a simplified version where the problem still occurs)?
(3,211 Views)
here.
When the graph is in log-log try to drag a cursor other than 0.
(3,168 Views)
Bonjour,
Si le Y vaut 0 ou Inf, en échelle log, le curseur n'apparaît pas dans la fenêtre du graph. Renseignez des valeurs de Y pour chaque curseur (double click dans la case correspondante) afin de les positionner dans la gamme d'amplitude couverte par votre graphe. Une fois que les curseurs appairaissent bien dans la fenêtre du graphe, il est tout à fait possible de les déplacer en cliquant - draggant la croix jaune qui les matérialisent...
Pierre-Emmanuel BELLES
Certified LabVIEW Developper
Certified TestStand Architect
(3,153 Views)
