Current control closed loop Maxon
Hello all !
I've trying to implement a closed loop current control to monitor a motor from Maxon with the EPOS4.
My setup :
Laptop with LabVIEW, EPOS4, Maxon's motor, load cell as a sensor.
I want to implement (in my imagination (dangerous) I need a PID.vi to make it work) the fact that depending on the value of the sensor and the set value, the current is set.
Do you think I use the right VI (for the PID), and do you think the closed loop should looks a bit like this ?
The first loop is in velocity mode so that the motor approach the sample with slow speed,
The second loop is current mode
I put my VI in case some one is interested and wants to have a look,
Bu sorry it's a bit messy, I've been trying loads of things.
Thanks a lot for your reading time in any cases !
Bastien.
Message 1 of 1
(1,385 Views)
