Cube Root
How do I take a cube root or any root larger than two? I cannot use the power function ie (x^(1/3). Thanks.
Message 1 of 8
(7,577 Views)
The "Power of X" function is in Numeric>>Logarithmic
Message 2 of 8
(7,577 Views)
Why not?
Les
Message 3 of 8
(7,577 Views)
It tells me must have an integer value.
Message 4 of 8
(7,577 Views)
Hi Jay,
maybe I didn't understand your problem, but I had no problems with roots.
Andreas
Message 5 of 8
(7,577 Views)
Use y=x**(1/3); in a formula node, or x**(1/3) in an expresion node.
Wiebe.
"Jay_Smasher@yahoo.com" wrote in message
news:50650000000800000041B40000-1068850981000@exchange.ni.com...
Message 6 of 8
(7,577 Views)
Hi
You should try e^(1/3*ln(x))
Bye
Message 7 of 8
(7,577 Views)
I see the problem. You are using the Expression Node. Look in the help for this:
^ bit exclusive or
** exponentiation
You are asking LabVIEW to do a bit "exclusive or" instead of exponentiation.
Les.Hammer@CompleteTest.com
Message 8 of 8
(7,577 Views)
