Crossbow to Labview
Hi everybody. I am trying to get the data from crossbow to labview. I am using Memsic WSN starters kit (MIB520 Gateway,MICA2 node, MTS400 sensor board ) and I am trying to get data from it into labview. I followed instructions from this webpage http://digital.ni.com/public.nsf/allkb/FD238ED75B22740B86257315004E35FE , but after all steps when I run Read Data and Display Health with Variable Rate.vi I just get an error 8003. Does anybody know what might be a problem and how I could fix it? Thank you.
(2,956 Views)
Hi Nikola100,
Does the error have any explanation with it?  The only information I have found regarding that error is if the instrument driver that you downloaded is not compatible with the version of LabVIEW that you have or if you are saving for a previous version.  What version of LabVIEW are you using and which Instrument Driver did you download?  Also, do you have the NI VISA driver downloaded?  Thanks!
Kim
(2,928 Views)
