Online shopping is currently unavailable.
Please contact us for help or try again later.
Creating shared object
I want to create a shared object (.so) of a VI.  Tools->Build Application from VI only provides me an option of creating a Stand Alone Project and not a shared object. Is there any other way I can do that? Could it be because I am using LV2009 trial version for Linux?
Thank you.
H.
(2,809 Views)
Creating a Shared Object works through the LabVIEW Project. You will need to create a Project, add your VI and configure the Build under "Build Settings" in the project tree.
A precondition is that you have the LabVIEW Application Builder (included in LV Professional).
I don't know which Eval Version for Linux you use, but you will need to have the Application Builder.
Christian
(2,787 Views)
