Creating several front panels (full display s
ize) within the same VI in LabVIEW In a case of compound application (more than 100 controls & indicators)is desirable to create several front panels within the same VI. How can I do that in LabVIEW 6.0. Just give me an idea or send me some examples. This problem I've easily solved in CVI. The front panels shold be active when the user is pressing control button.
(2,643 Views)
I can't remember if there are TAB controls in LV6.
If so, you could group controls and indicators by function and place them on TABs. While running, the user can select a different TAB for different function of the vi.
That's quite the vi if it has over 100 controls & indicators... ;o)
Hope you're having fun developping it!
-JLV-
(2,643 Views)
If you are looking to dynamically create controls and indicators, that
isn't possible in LV since the LV controls and indicators are more
closely coupled with your diagram code and aren't a just reference to
something on a panel. In LV this is typically done using an array
control. You make the display be a one or two dimensional array of
controls and then on the diagram, construct the data for the display
f
rom what you are measuring. Useful tools for this are the array to
cluster and cluster to array conversions.
In more complex cases, you might choose to have more than one array or
you switch to a cluster so that you can have individual properties and
not just individual data like the array has.
And in LV7, there is a new feature called the subPanel that lets you
display a sub-Panel within your display, which is more useful for
plug-in situations where it is difficult to predict what will need to be
displayed.
As the other post mentioned, with 100 displays, you may also want to use
a tab control to organize them and allow for better usage of screen space.
If you can be more precide about the display you are trying to make, we
can give better advice.
Greg McKaskle
(2,643 Views)
