Creating random timeseries in Labview to Arbitrary wave generator
I do not know anything about Labview but somehow i need to get this task done.
How do i make a random data time series using the data arrays in a text file to be generated into the arbitrary wave generator? Can somebody please provide an example file for this?
Thank you in advance.
(2,550 Views)
Hello Nazerrul,
There are several ways to do something like this.
First, many Arbs also have function generating capabilities, including random noise generation. What exact arb are you using?
If your arb doesn't have this capability you could use the Gaussian White Noise Waveform VI to create a noise waveform that you could then load into your arbitrary waveform generator. How to do this part depends on your arb. What exact arb are you using?
In short, more information is needed, including the arb you are using and what you have done so far in getting this to work.
Dan King
(2,546 Views)
