Creating controls dynamically...
hi,
    Can anyone tell me is it possible to create controlls (may be buttons) dynamically  during run time???
Also i have an application wherein i use a listbox for processing. How do i disable or enable an item alone during run time??
Jay
(5,030 Views)
Hi Jay,
for some information see this search result please http://forums.ni.com/ni/search?submitted=true&q=scripting.
There is an example from Ben and ?? (sorry, don´t remember the others), which shows how you can create a front panel, with using a picture control. Maybe an array of buttons can also help you.
You can connect an array of elements, to describe which elements you want to be disabled. Use a propety node for it.
Hope it helps.
Mike
Message Edited by MikeS81 on 08-04-2008 12:53 PM
(5,025 Views)
Now we can really  create controls dynamically. See this
http://forums.ni.com/ni/board/message?board.id=170&thread.id=443761
Tushar Jambhekar
tushar@jambhekar.com
Jambhekar Automation Solutions
LabVIEW Consultancy, LabVIEW Training
Rent a LabVIEW Developer, My Blog
(4,875 Views)
Tushar Jambhekar
(4,872 Views)
STOP spamming the board with multiple posts to the same link. One is enough!
(4,865 Views)
