Creating array
How to make array as shown in figure? In pairs of X and Y.
(4,712 Views)
Hi SSG,
basic LabVIEW knowledge:
1. Create a cluster, containing 2 elements named X and Y
2. Place that cluster in an array
Which of these two steps is a problem to you?
(4,695 Views)
If you want to build the cluster from two 1D arrays of X and Y values, wire the arrays in to a For loop, build a cluster from the elements then output the cluster from the loop.  Ensure that indexing is turned on for both inputs and the output tunnel mode is also set to indexing (right-click on the tunnel to check or set the mode).
Andy
(4,692 Views)
Accepted by topic author SSG0484
Hi Psy,
or just use Index&BundleClusterArray.
No need for a FOR loop…
(4,688 Views)
@GerdW
That's a very good point.  A function I so rarely use that I'd forgotton it was there.  Thanks for the reminder!
Andy
(4,678 Views)
