Creating and using vi templates example
Hi I am taking over some existing LV code where the programmer created 8 exact copies of the same vi with different names.  As you can image this is a maintenance nightmare.   So I was reading about using vi templates to create 8 instances of my same sub vi here: https://www.ni.com/docs/en-US/bundle/labview/page/creating-template-vis.html
I have attached an image of my labview code and utimately would like to have 8 references to new vis spawned off 1 template VI.  Is there an example or does anyone have any guidance on how to achieve this?
(4,247 Views)
Look at the shipping examples "Populating the Asynchronous Call pool.vi" ans Asynchronous Call and Collect (Using option 0x04).vi
Using a VIT at run time is obsolete with the Asynchronous Call By Reference node.
Leave your VIT's in <LabVIEW>\Templates for "File>>New..."
"Should be" isn't "Is" -Jay
(4,231 Views)
