Creating and connecting images to indicate tag values
I am trying to create a simplified version of our plant layout on my front panel using images from the image navigator. I would like to create, for example, a rectangle and have it shown green when my discrete tag value is 1 and red when my tag value is 0. I know how to code this for LEDs, however the images I lay down on the front panel do not give me the same options. (and I can’t find a simple rectangle on the image navigator??)
If anyone has any experience using this tool, I would like to know the steps involved from dragging an image on to the front panel to coding an image in the way described above.
Thanks for the help,
Stuart
(2,577 Views)
you can costumize a boolean with 2 differents picture.
See the example "Control Mixer Process.vi"
(2,564 Views)
As the previous post mentions, search for threads on "customizing controls", there have been a number of those. Unfortunately, what you are describing, available in most of the SCADA packages (Intellution, Wonderware, etc.) isn't available in LabVIEW. To do it requires opening a boolean indicator (LED, etc.) in the control editor and then pasting in the appropriate images, doable, but a lot of work to get good looking, controllable images.
Good Luck,
P.M.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(2,559 Views)
