Creating an interactive Grid
I'm trying to create an interactive grid where the blocks on the grid change their colors when user click on them and outputs the colored indices when the user clicks the stop button. I was able to modify the example from the link below to work for my project. Now, I'm trying to add another case to (case 4) but it doesn't work. When I ran the program, it was able to recognize and call the correct case number (#4) but then it went back to the default case instead. Please help!
Thanks in advance!
https://forums.ni.com/t5/LabVIEW/how-to-create-an-interactive-rectangular-grid-in-labview/m-p/160068...
(3,722 Views)
Save for 2015 pls?
CLD; LabVIEW since 8.0, Currently have LabVIEW 2022 SP1 installed
(3,697 Views)
Accepted by topic author SegFault1119
Never mind - link was in 2015.
Here is example for case 4
James
(3,695 Views)
Hi James,
Thanks for your solution. Could you also explain why my program didn't work?
(3,666 Views)
@SegFault1119 wrote:
Hi James,
not if you don't post it saved back into 2015 for me to be able to open, but If you do I will.
James
(3,637 Views)
