Creating an array via two cases element-by-element
Do you want both accels on the same graph sharing the packet for the X values?  I was confused why you had 2 graphs in your attached VI.
Well if you want them on one graph, then try the attached.
Chris Co
Message 11 of 14
(646 Views)
Ah, excellent Chris, thank you! As for the two graphs, I have to plot all values where "Mote" is 75 on one graph, and the values where "Mote" is 1 on the other. It's confusing I know, but don't shoot the developer. 🙂
Ryan
Message 12 of 14
(639 Views)
Here's a simple modification that plots "mote 1" data and "mote 75" data on seperate graphs.
Message 13 of 14
(629 Views)
Yep, I actually had almost exactly what you did this time around. Thank you all so much, once again.
Ryan
Message 14 of 14
(622 Views)
