Creating an XY graph from a while loop
Greetings,
I am having trouble bundling information from a while loop into a XY graph. I want to be able to vary the start time and end time of my graph, ultimately graphing amplitude vs time. Increments in 0.1 seconds.
Attached is a vi & Word document w/ a screen shot of my front and block diagram.
Thanks for your help.
I
Message 1 of 11
(4,594 Views)
check this if it help you getting started
... And here's where I keep assorted lengths of wires...
Message 2 of 11
(4,581 Views)
Thank you, it works like a charm. Do you have any idea I how I could obtain the slope at two random points?
Message 3 of 11
(4,569 Views)
Thanks again,
I have a few questions. Would bundle have worked my requirements? All of the examples (with For Loops) showed bundle and nothing with the While Loop. I spend alot of time last night and this morning wrestling w/ trying to bundle.
Newbie 2
Message 4 of 11
(4,560 Views)
yes bundle would have worked for an xy graph:
you bundle the x array with the y array and send the cluster to the graph.
in this case the x array could have been for example the index of the loop.
there is no fundamental difference between a for loop or a while loop in this regard, and the shift register (keeps the data between iterations of the loop) works the same way.
Message 5 of 11
(4,551 Views)
Hum that is a little involved, as you have to define what are going to be your points.
the slope itsdelf very easy as soon as you have defined them: you can use directly the fit function in the mathematics panel, or calculate it yourself.
for picking up the points from the graph, there is no easy way that i know of, and this will require a small program of its own.
Message 6 of 11
(4,549 Views)
in this thread you will find very interresting examples set by Altenbach for moving points on a graph (example 1), and maybe connecting them to original data points (example 2)
Message 7 of 11
(4,546 Views)
I am not sure how I would pick off the x-axis to give me the increments. Would I create a separate loop as you have shown? Also, any time I timed to specify a constant for the increment, the constant option wasn't available.
Thanks for your time and help.
Message 8 of 11
(4,546 Views)
look at this vi.
the x array is created out of the index.
Message 9 of 11
(4,522 Views)
Gabi1
Thank you again for your help! I've learn this morning from your help than I would typically learn in class for an evening.
Thank you
Message 10 of 11
(4,506 Views)
