Creating a subvi from a selection using VI scripting
I am having a Main VI which has many while loops and is spread across in many screen sizes. I wanted to make a subVI of the nodes selected in the Block Diagram using VI Scripting. I had found a method called AbstractDiagramClass/subVI from Selection method. But I am not able to find it in my LabVIEW 2023.
If someone has used something similar, please do share. Thanks
(1,255 Views)
Here.
In order to be able to select that method, and other private methods,
Add these lines to labview.ini
SuperPrivateScriptingFeatureVisible="True"
SuperPrivateSpecialStuff="True"
SuperSecretPrivateSpecialStuff="True"
(1,218 Views)
