Creating a fixed size array Producer-Consumer loop
I already uploaded my code because of some issues I was facing. I improved my code a bit. I am reading samples from FPGA and on the PC side; I want to store only a specific number of elements. For example, if I want to store 10 elements in an array, after 10 elements I want to remove the oldest element and place a new one in its place how can I do that any suggestions. So in this way, I want to remove old elements one by one and place new ones keeping the array size constant.
I have attached my code with the post.
(1,883 Views)
Hi kazmi,
you really should know this when you are working with FPGA code:
(1,843 Views)
Hello Gerd,
Solved it already thanks a lot for the reply.
(1,837 Views)
