Creating a datalog file
Hi all!
I am trying to create a new datalog file with a specific structure ( cluster structure). But when I run the following vi, I get an error message - LabVIEW: (Hex 0x4) End of file encountered.
(1,737 Views)
Once I give it new file name, I don't get any errors.
  • Not sure why your dialog is set to "file or folder", because selecting a folder would probably not make much sense.
  • Since you also allow selection of existing files, could it be you are selecting a file that already has datalog entries with a different structure?
(1,697 Views)
Thank you so much for your suggestions! Now I am creating a new file whenever I create a new Datalog file rather than using an existing one. Also, I would like to ask, is there anyway labview attaches the extension by it's own? rather than me having to add it whenever I create a new file..
(1,671 Views)
Hi ms6,
Why should the programming language be responsible to create filenames by it's own based on your requirement?
You create the program, you define the filename: you can create the code needed to build your filename!
(1,663 Views)
I doubt you have to create a new file every time as long as you don't change the datalog type.
The filename and file extension is just a string and there is a palette full of string function that allows you to manipulate all parts. (such as adding/changing an extension). Once you settled on a suitable extension, you can set the pattern for the file dialog so you only see these files.
(1,616 Views)
