Creating a counter
Could some one guide me on how to create a counter in labview I want to create a counter that starts at 0000 and ends at 1111.
Any help would be appreciated
Thanks.
(4,072 Views)
What kind of things do you want to count?
(4,067 Views)
The counter will be used to acess RAM memory locations so I need to start at 0000 and increment bu 1 bit until I have 1111
(4,064 Views)
Doesn't come much simpler than this.
You should go to http://www.ni.com/devzone/lvzone/fundamentals.htm and look at all of the resources available for learning the basics of LabVIEW. Reviewing the shipping examples of LabVIEW program would also be a very worthwhile exercise.
Message Edited by Dennis Knutson on 03-03-2006 09:30 AM
(4,049 Views)
I think aztlan wants to count in binary- 0000, 0001, 0010,0011....1111.
Could use the for/next loop method and convert the number to a binary array of 4 bits. Then use the bits to fire digital outputs connected to the memory's address lines (if in fact this is a physical device)
(4,032 Views)
I almost suspect that you want to go from binary 0000 to binary 1111, so just set the loop counter in Dennis' example to 16 and set the display of the indicator to (format: binary, 4 digits, pad with leading zeroes). 🙂
(4,032 Views)
Thanks this really helps. Thats is exactly what I want t do.
(4,024 Views)
