Creating a control panel for digital output
Hi everyone. I'll start by saying i'm rather new to labview, and i searched the forum properly before posting.
I'm trying to control an AC motor terminal using a cDAQ and the NI 9401 digital I/O card.
I have the logic table for the terminal, but am having a hard time managing to implement it in a convenient way- i'd like there to be 3 buttons, fwd/reverse/stop, and the operation needs to be in real time.
The way i tried going about it- number to boolean array, integer to boolean. But i can't find a way to give the buttons themselves numerical value, or connect a few "integer to boolean" outputs to a single "read" function for the cdaq channel, so i can control the operation live.
(example- 3 buttons, valued "1000", "1001", "1011", each time one of them is pressed, the corresponding digital signal is sent via wires 0-3 on the card itself)
Any suggestion or help would be much appreciated.
(2,525 Views)
Am I understanding correctly? You are trying to control a motor with digital commands using a front panel with buttons corresponding to 3 different digital commands that you want to send? If so, I would use an event structure.
Initialize DAQmx before the while loop and then have an event structure with 4 cases [FWD value change; REV value change; STOP value change; CLOSE value change (use a 4th button to end the application)]. Each of the first three events will send a digital command. The last one will just exit the loop. After the event loop, close DAQmx. Research event structures a little bit. They aren't very difficult. There are examples and other information out there. If you have specific questions that you don't have answers to, use this same feed.
(2,496 Views)
