Creating a VI for a pump (VFD)
I need to control a US Electric pump (VFD) using LabVIEW. I have NI FP-1000 that's connected to FP-CTR-5000 and FP-TB-10. The other equipments that I will be using are Hart 202 modem, RS-485 modem, Win XP, LabVIEW 7.1. Anyone has a LabVIEW program that's written for a similar setup. If you do, could you please kindly forward to me.
New to LabVIEW
(2,661 Views)
Hermonite,
I am assuming you meant that you had an FP-TB-1 terminal block, not an FP-TB-10, which is used for dual channel modules -- the FP-CTR-500 requires the PF-TB-1.
I don't know exactly what you want to do with the FP-CTR-500, but it sounds like you may be wanting to do pulse width modulation.  The FP-CTR-500 can do pulse train generation, but if you want to do pulse width modulation, there are specialized Fieldpoint modules for doing that such as the PF-PWM-520.
I hope this helps!
Doug M
Doug M
For those unfamiliar with NBC's The Office, my icon is NOT a picture of me 🙂
(2,642 Views)
