Creating a Labview Array initialised with data from a C array
I'm looking to create a 1-D array with integer data. I've got the list of values to go into the array currently in a C file format (ie each number followed by comma then newline).
The data doesn't need to be wrapped up inside a DLL or anything fancy.
Whats the most straightforward way of creating the 1D Labview array initialised with values specified?
(2,585 Views)
I'm not sure what you mean by "C file format". It sounds like you have a plain text file. If you have something like:
5,
15,
23,
4,
999,
then use Read From Spreadsheet File and use a %d format. If you select transpose, the first row output will be a 1D array of your file.
(2,577 Views)
