Creating a GUI for a State Machine
Hello Udka,
I know it would work that way, but the enum itself is changed often while I'm in the programming process. Plus others probably want to alter the state machine later, so changing the values of the tab control everytime the states change (so the eum, too) would probably cause a lot of worries. I thought it would be nice to somehow manipulate the tab control, that it always has the same values and names in the tabs like the enum since they are of the same type. I just thought there was an easy solution to it since I'm quite new to Labview.
Regards
Simon
Message 11 of 12
(695 Views)
Rather than using a tab control I would suggest using subpanels. It is much easier to add new cases since you are dynamically loading the subpanels.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 12 of 12
(671 Views)
