Creating URL path for OPC
I am using LabVIEW 8.6 to read/write to the PLC (Allan Bradley 1100) using the OPC server provided by RSLogix 500. I found an existing VI for monitoring multiple PLC tags (Multiple OPC Items Monitor)  and it works if I use selection of the items option. However, I was trying to change the list of predetermined items and I have trouble figuring out the syntax for the URL. I also don't understand how the URL differs from a file path constant and was wondering if there was a way to convert.
Thank you.
(6,311 Views)
Not sure I understand what you are asking here but do you want to know the syntax of Datasocket OPC URL's?
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(6,300 Views)
Yes, I would like to know the syntax.
(6,298 Views)
Datasocket Tutorial - OPC [link removed; article no longer available]
If you have any other questions, post back.
Adnan Zafar
(6,296 Views)
I checked the link and I'm still not sure if what I have is correct. The link states:
opc://ServerName/OPCServer/ItemName.
By my logic what I want should look like:
opc://RSLinx OPC Server/RTTA/Online/F8/F8:1
RTTA, online, and F8 being folders
When I use the above stated URL I get an error message stating that it can not read items.
I appreciate any help you can offer.
(6,290 Views)
No, you just need to bind to the item name. What's the tag identified as in your OPC? Link it directly to that; you don't need to specify folders.
Adnan Zafar
(6,270 Views)
